[mapguide-users] Re: (1092688208) Resource was not found:
Library://Samples/Layouts/Sample.WebLayout
Dave Wilson
dave.wilson at autodesk.com
Mon Mar 22 19:18:36 EDT 2010
Can you also check with a phpinfo test page? It may be an issue with PHP not loading. I suspect the build you have is 32bit PHP from 5.2.25 and we are only just updating PHP to 5.3.1. It may be the 32bit PHP on 64bit doesn't play well.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, March 22, 2010 5:11 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: (1092688208) Resource was not found: Library://Samples/Layouts/Sample.WebLayout
Have you set display_errors = On in your php.ini? It may reveal more
information.
- Jackie
View this message in context: http://n2.nabble.com/1092688208-Resource-was-not-found-Library-Samples-Layouts-Sample-WebLayout-tp4780445p4781191.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
