[mapguide-users] Re: (1092688208) Resource was not found: Library://Samples/Layouts/Sample.WebLayout
kfwebb at bombasticlocution.com kfwebb at bombasticlocution.com
Mon Mar 22 21:05:17 EDT 2010
Thank you for your reply Dave.
phpinfo() checks out OK. I was using it extensively earlier on in the
process when I was getting undefined function MgInitializeWebTier errors
(My fault for mixing-and-matching php versions).
But now I am on to "newer" and "fresher" territory.
There were complaints that mapviewerphp/mapagent/mapagent.fcgi didn't
exist, and it didn't. Copying www/mapagent/mapagent.fcgi to
www/mapviewerphp/mapagent/ corrected that.
Now I am getting failures on
http://localhost:8008/mapviewerphp/legend.php?MAPNAME=Sheboygan&LC=0&SESSION=10565af8-1842-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA
http://localhost:8008/mapviewerphp/mapagent/mapagent.fcgi?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=10565af8-1842-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA&MAPNAME=Sheboygan&SEQ=0.34844492131190397&CLIENTAGENT=Ajax%20Viewer&BEHAVIOR=2&SETDISPLAYDPI=96&SETDISPLAYWIDTH=1183&SETDISPLAYHEIGHT=454&SETVIEWSCALE=undefined&SETVIEWCENTERX=-87.7302542509315&SETVIEWCENTERY=43.744459064634&CLIENTAGENT=Ajax%20Viewer
http://localhost:8008/mapviewerphp/mapagent/mapagent.fcgi?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=10565af8-1842-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA&MAPNAME=Sheboygan&SEQ=0.6036073856391289&CLIENTAGENT=Ajax%20Viewer&BEHAVIOR=2&SETDISPLAYDPI=96&SETDISPLAYWIDTH=1183&SETDISPLAYHEIGHT=261&SETVIEWSCALE=undefined&SETVIEWCENTERX=NaN&SETVIEWCENTERY=NaN&CLIENTAGENT=Ajax%20Viewer
The Apache log is showing a complaint
Status: 559 MgConfigurationLoadFailedException
Content-type: text/html; charset=utf-8
<html>
<head>
<title>MgConfigurationLoadFailedException</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
</head>
<body>
<h2>Configuration file "../webconfig.ini" cannot be found or cannot be
opened.</h2>
opened.
</body>
</html>
I do have a webconfig.ini in the www directory. Not certain about the
relativity of the ".." in the "../webconfig.ini." I suspect it might be
a result of calling mapagent.fcgi from inside www/mapviewer/mapagent
instead of www/mapagent.
Getting closer!
KFW
On Mon, 2010-03-22 at 16:18 -0700, Dave Wilson wrote:
> Can you also check with a phpinfo test page? It may be an issue with PHP not loading. I suspect the build you have is 32bit PHP from 5.2.25 and we are only just updating PHP to 5.3.1. It may be the 32bit PHP on 64bit doesn't play well.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Monday, March 22, 2010 5:11 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: (1092688208) Resource was not found: Library://Samples/Layouts/Sample.WebLayout
> Have you set display_errors = On in your php.ini? It may reveal more
> information.
> - Jackie
