[mapguide-users] Re: Dynamically Setting Initial Map Position and
Scale
Nickthetemp
nickthetemp at gmail.com
Wed Mar 31 08:42:19 EDT 2010
In studio (I am using 2010), open up the weblayout that you have created for
the map.
Near the top there is a section called "initial view of the map". There is 2
radio buttons and the default is set to "Use map's initial view"
You have to select "Use custom view"
hope this helps
Nick
View this message in context: http://n2.nabble.com/Dynamically-Setting-Initial-Map-Position-and-Scale-tp1818865p4830566.html
