[mapguide-users] building 64bit openmapguide on rhel 5.4
Zac Spitzer zac.spitzer at gmail.com
Wed Mar 31 19:50:15 EDT 2010
migrating away from using all these third party libs in the oem tree
on linux and use the system ones when possible is a better approach
On 1 April 2010 10:34, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi Rajeev,
> Third party components can be very tricky business in MapGuide.  For example, Berkeley DB XML uses specific versions of xerces and xalan.  These three third party libraries should remain in sync to ensure repository stability.  In order to compile with GCC 4.4, we will need to update a significant portion of the Oem tree.  Since we are about to hit beta, I would say any additional changes to third party / Oem libraries would have to be considered on a case by case basis.
> Hopefully our existing set of third party libs will compile successfully on 64 bit Linux.  If not,  RFC's will have to be written to get the libraries upgraded.  For example, RFC 89 http://trac.osgeo.org/mapguide/wiki/MapGuideRfc89 was a required upgrade for 2.2.
> As for source code modifications, yes there have been a few (geos,swig,agg,others?).  I do not know if the modifications have made it back into their respective projects.
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rajeev Singh
> Sent: March 31, 2010 7:02 AM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] building 64bit openmapguide on rhel 5.4
> Hi Trevor,
> I will certainly look into this - though adam probably will get to it
> sooner. Right now finally gotten around to looking at 32 bit crash of 2.0.2
> branch (had filed a bug earlier, essentially every 1/2 hr or so the process
> crashes).
> As an aside, when going thru the attempt on 2.0.2, I did complie FDO 3.3.2
> on 64 bit (compiled  all except a few dealing with ODBC/PostGis/Oracle, but
> including MySQL)
> On a different note, lots of third party components are used with mapguide.
> At some point I think I had seen in some mailing list that the source code
> have been modified. Is that really so or can we instead create a packaging
> that uses the latest / required binaries of those components (I can help
> with that)
> thanks
> rajeev
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
