[mapguide-users] Mag Guide setup on II7 2008 Server Issue, Please help
Jonathon McIntyre johnniegis at gmail.com
Wed May 5 14:46:08 EDT 2010
Hi Tori,
I am assuming that you have made sure that the fcgi is included in the
handler mappings?
Also, I have had issues where I have had to add the mapagent.fcgi to the
default documents to get it to work...can't explain for the life of me why
this would make even be required...
Finally, make sure that your app pool is set to run in classic mode.
Hope this helps.
Best regards,
Jonathon
i-open Tech
On Wed, May 5, 2010 at 11:15 AM, Victoria (Tori) Myers <
tmyers at jeffersoncountywv.org> wrote:
>  Hello,
> I have had MGOS working on the old XP box for testing, now I am trying to
> install it on the production Windows Server (64 bit) 2008 with IIS7. I am
> almost to the point of adding Apache to that server on a different port and
> using it like that. But, perhaps you may be able to help.
> I have tried installing MGOS using the instruction for 2008 server on IIS7
> (I found three different sets of instructions for that and none work
> completely), the best one, so far was at geospecialling.com. (Installing
> and uninstalling on a working server is not a lot of fun. I have done it
> four times now. Thankfully it is under my control and I can check when there
> are no users.)
> So, I have MGOS installed (as best as I can so far and configured, again,
> as best as I can so far) I have php.info working, FCGI working (according
> to phpinfo), the administrator pages working and the agent pages come up but
> all of the tests (that I have tried) fail  with a cannot establish
> connection error. I get the same error in Maestro. I have tried the maps
> (sheyboygan is loaded but nothing is returned). I tried goggling fcgi, fcgi
> IIS7, fcgi 401.5, mapguide fcgi, etc, etc. Looking in forums, etc.  I cannot
> find an answer to this so I am asking if anyone might have a solution or at
> least point me in the direction to begin troubleshooting it.
> Looking in the logs it is a 401.5 meaning the FCGI requires a login but it
> doesn’t ask for one and I have authorization set to anonymous and
> application pool.
> Any suggestions?
> Thanks, Tori
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100505/429dc973/attachment.html
