[mapguide-users] Re: Mag Guide setup on II7 2008 Server Issue,
Please help
Steve G
steve.golden at morganhill.ca.gov
Wed May 5 18:03:24 EDT 2010
Tori,
I am working on a Windows Server 2008 (64 bit) with IIS7 and have been able
to successfully get mapguide working a few times using the instructions
found at:
http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
Yes, the documentation is not great, but follow it exactly. If you have
tried building the site, failed, and reinstalled mapguide (or made a "new"
connection to mapguide) be sure to completely remove the previous
application(s) from IIS. You need to find the application window and remove
the applications (virtual paths to /mapguide, /mapguidemapagent, and
/mapguide/mapviewerajax). If you simply remove the connection to the
mapguide website, I believe the applications persist. At least that is what
I found.
I am having problems viewing raster ECW files (I've completed the same GDAL
FDO configuration as my XP box), but that is another story.
-Steve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mag-Guide-setup-on-II7-2008-Server-Issue-Please-help-tp5010394p5011371.html
