AW: [mapguide-users] How to use Custom LineStyle
SriRam007
binod_tripathy at yahoo.co.in
Thu May 6 01:24:19 EDT 2010
Hello everyone,
I went through the PDF file and understood the process.
But still i m not getting how to implement it.
Dynamically can i do this?
Is there any static way?
If i want to do it dynamically Should i create all the tags dynamically
inside the layer definition file.
and have to remove the linetypestyle tag??
<CompositeTypeStyle>
<CompositeRule>
<LegendLabel>Test</LegendLabel>
<CompositeSymbolization>
<SymbolInstance>
<ResourceId>Library://Path/To/File.SymbolDefinition</ResourceId>
<ParameterOverrides>
<Override>
<SymbolName>Fault</SymbolName>
<ParameterIdentifier>LINE_WEIGHT</ParameterIdentifier>
<ParameterValue>1.0</ParameterValue>
</Override>
</ParameterOverrides>
</SymbolInstance>
</CompositeRule>
</CompositeTypeStyle>
thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/AW-mapguide-users-How-to-use-Custom-LineStyle-tp5003379p5012601.html
