AW: [mapguide-users] How to use Custom LineStyle
Jason Birch jason at jasonbirch.com
Thu May 6 02:12:32 EDT 2010
Have you downloaded and installed the sample package (and read the other
resources) on this page:
http://trac.osgeo.org/mapguide/wiki/AdvancedStylization
<http://trac.osgeo.org/mapguide/wiki/AdvancedStylization>and looked at the
line style definition here:
http://trac.osgeo.org/mapguide/wiki/AdvancedStylization/Library/Transportation
These should get you on your way.  I think, but am not sure, that you can
inline the stylization in the layer definition.  The XSD should make this
fairly clear if you want to dig into it.  Personally, I would just create
the symbol definition as a separate resource in the session repository and
reference it from my session layer definition.
Jason
On 5 May 2010 22:24, SriRam007 wrote:
> I went through the PDF file and understood the process.
> But still i m not getting how to implement it.
> Dynamically can i do this?
> Is there any static way?
> If i want to do it dynamically Should i create all the tags dynamically
> inside the layer definition file.
> and have to remove the linetypestyle tag??
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100505/997482f9/attachment.html
