[mapguide-users] RE: Cannot get any DSN for ODBC Provider
Jonathon McIntyre johnniegis at gmail.com
Thu May 6 12:16:19 EDT 2010
Good morning,
I am not sure whether you are using the 64 bit or 32 bit ODBC Data Source
Administrator.
I was using the default Windows 7 ODBC Data Source Administrator and could
not find the Data Sources in MS Access so I opened the 32 bit ODBC Data
Source Administrator (on my machine in C:\Windows\SysWOW64\odbcad32.exe)
created the ODBC data sources there and was able to see and use the Data
Sources.
Hope that helps,
Best regards,
Jonathon
i-open Tech
On Thu, May 6, 2010 at 12:33 AM, Gunter Becker <gunter.becker at csogis.de>wrote:
> Hi James,
> your totally right. Windows 7 and Windows Server 2008 are 64Bit machines
> and
> my Windows XP is 32 Bit.
> I will see if the solution in the link works for me.
> Thanks, Gunter
> http://osgeo-org.1803224.n2.nabble.com/Cannot-get-any-DSN-for-ODBC-Provider-tp5011323p5012979.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100506/e7512733/attachment.html
