[mapguide-users] Compiling fusionSF.js
Tom Fukushima
tom.fukushima at autodesk.com
Fri May 21 09:01:44 EDT 2010
This page has some instructions on how to get the source from subversion:
http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22
You will need to adjust some of the paths based on the version of MGOS that you are using.
E.g., MGOS 2.1: svn export http://svn.osgeo.org/fusion/branches/fusion-2.0 mgdev/Oem/fusion
(The location above can be found by looking at the externals tag of the Oem directory.)
I believe that once you have the source, you then just need to follow the instructions in the BUILDING.TXT file found in the root directory. I would think that you probably want to use "ant compress" or "ant singlefile".
Tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
Sent: Friday, May 21, 2010 6:32 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Compiling fusionSF.js
Anybody know how can I obtain the file fusionSF.js from the SVN? I see the
YUI build proyect, but a step by step or more information will be
appreciated
Thks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compiling-fusionSF-js-tp5084021p5084021.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
