[mapguide-users] Compiling fusionSF.js
Mike Adair
madair at dmsolutions.ca
Fri May 21 11:05:41 EDT 2010
And there is more info on creating the single file version of Fusion
here: http://trac.osgeo.org/fusion/wiki/ANTBuildSystem
Mike
Tom Fukushima wrote:
> This page has some instructions on how to get the source from subversion:
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22
> You will need to adjust some of the paths based on the version of MGOS that you are using.
> E.g., MGOS 2.1: svn export http://svn.osgeo.org/fusion/branches/fusion-2.0 mgdev/Oem/fusion
> (The location above can be found by looking at the externals tag of the Oem directory.)
> I believe that once you have the source, you then just need to follow the instructions in the BUILDING.TXT file found in the root directory. I would think that you probably want to use "ant compress" or "ant singlefile".
> Tom
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
> Sent: Friday, May 21, 2010 6:32 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Compiling fusionSF.js
> Anybody know how can I obtain the file fusionSF.js from the SVN? I see the
> YUI build proyect, but a step by step or more information will be
> appreciated
> Thks.
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
