[mapguide-users] Re: Maestro Layout Task frame menu search filter syntax?
Tori_M tmyers at jeffersoncountywv.org
Tue May 25 16:50:33 EDT 2010
OK, I will answer my own question for anyone else having the same trouble I
was.
The Format is: "Field_name" LIKE '$USER_VARIABLE%'
Works like a charm once you know the syntax.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-Layout-Task-frame-menu-search-filter-syntax-tp5100122p5100424.html
