[mapguide-users] RE: Measuring distances mismatch
Rico (giskit) rico at giskit.nl
Wed May 26 04:52:30 EDT 2010
Hi List,
I am also struggeling with this problem. I have some questions about the
solutions mentioned in this thread.
I have map in "XY-M (Arbitrary X-Y Coordinates (Meters))" coordinate system.
The values given by the mease tool are wrong (factor 11000 or so). What kind
of projection code should i use for arbitrary XY?
I tried to use the EPSG 28992 coordinate system (dutch national grid). Then
i have got the Proj4js error. The solution mentiond by brian was to use the
fusion.js instead of fusionSF.js. But how can i do this?
Rico
Berdel, Brian wrote:
> Mike is right about this...Now I remember I did have to specify a
> projection...
> In svn I think you need to use fusion.js rather than fusionSF.js
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
> Sent: Thursday, May 20, 2010 11:10 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Measuring distances mismatch
> Thks Mike for this information about ProjectionDef. Unfortunatelly, the
> Proj4js in the Mapguide throw me the next error (Firebug): Proj4js is not
> defined on line 61088 from fusionSF.js.
> My projection is:
> <ProjectionCode>EPSG:23030</ProjectionCode>
> <ProjectionDef>+proj=utm +zone=30 +ellps=intl +units=m
> +no_defs</ProjectionDef>
> http://osgeo-org.1803224.n2.nabble.com/Measuring-distances-mismatch-tp5074175p5080114.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to the
> printed copies (also known as 'hard copies') that are signed and sealed by
> the Engineer and/or Land Surveyor. Files in electronic formats, or other
> types of information furnished by the Engineer and/or Land Surveyor to you
> such as text, data or graphics are for your convenience only. Any
> conclusions or information obtained or derived from such electronic files
> will be at the user's sole risk. When transferring documents in electronic
> formats, the Engineer and/or Land Surveyor makes no representation as to
> long-term compatibility, usability, or readability of the documents
> resulting from the use of software application packages, operating systems
> or computer hardware differing from those used by McMahon Associates, Inc.
> at the beginning of the project.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Measuring-distances-mismatch-tp5074175p5102494.html
