[mapguide-users] Re: Using DigitizePoint(handler) Errors
Jackie Ng jumpinjackie at gmail.com
Thu Nov 4 01:18:14 EDT 2010
The handler in DigitizePoint(handler) is not a point, it is a function that
accepts a point parameter (the point that was digitized.
So your code should look something like this:
function OnPointDigitized(p)
    document.write(p.x);
    document.write(p.y);
function getPoint() {
    opener.top.showMap.mapFrame.DigitizePoint(OnPointDigitized); //the
structure
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-DigitizePoint-handler-Errors-tp5704197p5704213.html
