[mapguide-users] GoogleMap on MGOS
ar_gaeta
ar_gaeta at yahoo.it
Mon Nov 8 12:16:42 EST 2010
I have a problem loading a GoogleMap layer on my flexible layout on MGOS
v2.2.
In a lot of forum I've got a lot of solution but they didn't work for me.
Or, better, I'm losing something on the way.
The 2 solutions proposed:
1-http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
2-http://research.dmsolutions.ca/?p=314
Here I put the first part of my ApplicationDefinition, and the string added
to my "index.html" of the weblayout template (in my case, I've tried on
slate):
ApplicationDefinition - row changed:
<MapSet>
<MapGroup id="googleBase">
<Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<Options>
<isBaseLayer>false</isBaseLayer>
<userOverlay>true</userOverlay>
<projection>EPSG:900913</projection>
</Options>
<ResourceId>Library://prova_basic/Map/mappa-google.MapDefinition</ResourceId>
</Extension>
</Map>
<Map>
<Type>Google</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>google</ResourceId>
<Options>
<type>G_SATELLITE_MAP</type>
</Options>
</Extension>
</Map>
</MapGroup>
</MapSet>
Index.html - row added:
<script
src="http://maps.google.com/maps?file=api&v=2&sensor=true&key=ABQIAAAAJPK2JAvznfdLjCCKOo0--RRv5cmsqmyFG_VJkA8rJhF-J1gmJBSIK-D-YjT4JQNWaLbsvp5rqNEHbQ"
type="text/javascript"></script>
<script type="text/javascript"
src="../../../lib/fusionSF-compressed.js"></script>
src="http://127.0.0.1:8008/mapguide/fusion/lib/fusion.js"></script>
src="http://www.openlayers.org/api/OpenLayers.js"></script>
src="http://127.0.0.1:8008/mapguide/fusion/layers/MapGuide/MapGuideViewerApi.js"></script>
var addGoogleStuff = function() {
var mapWidget = Fusion.getWidgetById('Map');
var map = mapWidget.oMapOL;
mapWidget.fractionalZoom = false; //fractionalZoom not permitted
with Google layers
map.setOptions({fractionalZoom: false, numZoomLevels: 30});
// Create a Google streets layer
var googleStreetsLayer = new OpenLayers.Layer.Google('Google Streets',
{type : G_NORMAL_MAP, isBaseLayer: true, sphericalMercator: true});
map.addLayer(googleStreetsLayer);
var mgLayers = map.getLayersByClass('OpenLayers.Layer.MapGuide');
if(mgLayers.length != 0)
var mgLayer = mgLayers[0];
if(mgLayer.isBaseLayer)
map.setBaseLayer(googleStreetsLayer);
mgLayer.setIsBaseLayer(false);
mgLayer.setVisibility(true);
When I load my layout nothing happen, just I can see the various frames of
the pages but they are empty.
With the "searcher bug" of GoogleChrome I've found that "map.js": "canno't
read property "maps" of undefined".
Someone can help me please?
Tnx in advance,
Riccardo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GoogleMap-on-MGOS-tp5717706p5717706.html
