[mapguide-users] GoogleMap on MGOS
Jason Birch jason at jasonbirch.com
Mon Nov 8 17:03:28 EST 2010
I don't remember the details, but there's an outstanding defect in
Fusion for the commercial layers.
On 2010-11-08, ar_gaeta <ar_gaeta at yahoo.it> wrote:
> Hi,
> I have a problem loading a GoogleMap layer on my flexible layout on MGOS
> v2.2.
> In a lot of forum I've got a lot of solution but they didn't work for me.
> Or, better, I'm losing something on the way.
> The 2 solutions proposed:
> 1-http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> 2-http://research.dmsolutions.ca/?p=314
> Here I put the first part of my ApplicationDefinition, and the string added
> to my "index.html" of the weblayout template (in my case, I've tried on
> slate):
> ApplicationDefinition - row changed:
> <MapSet>
>     <MapGroup id="googleBase">
>       <Map>
>         <Type>MapGuide</Type>
>         <SingleTile>true</SingleTile>
>         <Extension>
>           <Options>
>             <isBaseLayer>false</isBaseLayer>
>             <userOverlay>true</userOverlay>
>             <projection>EPSG:900913</projection>
>           </Options>
> <ResourceId>Library://prova_basic/Map/mappa-google.MapDefinition</ResourceId>
>         </Extension>
>       </Map>
>       <Map>
>         <Type>Google</Type>
>         <SingleTile>false</SingleTile>
>         <Extension>
>           <ResourceId>google</ResourceId>
>           <Options>
>             <type>G_SATELLITE_MAP</type>
>           </Options>
>         </Extension>
>       </Map>
>     </MapGroup>
>   </MapSet>
> Index.html - row added:
> <script
> src="http://maps.google.com/maps?file=api&amp;v=2&amp;sensor=true&amp;key=ABQIAAAAJPK2JAvznfdLjCCKOo0--RRv5cmsqmyFG_VJkA8rJhF-J1gmJBSIK-D-YjT4JQNWaLbsvp5rqNEHbQ"
> type="text/javascript"></script>
> <script type="text/javascript"
> src="../../../lib/fusionSF-compressed.js"></script>
> src="http://127.0.0.1:8008/mapguide/fusion/lib/fusion.js"></script>
> src="http://www.openlayers.org/api/OpenLayers.js"></script>
> src="http://127.0.0.1:8008/mapguide/fusion/layers/MapGuide/MapGuideViewerApi.js"></script>
> var addGoogleStuff = function() {
>     var mapWidget = Fusion.getWidgetById('Map');
>     var map = mapWidget.oMapOL;
>     mapWidget.fractionalZoom = false;        //fractionalZoom not permitted
> with Google layers
>     map.setOptions({fractionalZoom: false, numZoomLevels: 30});
>     // Create a Google streets layer
>     var googleStreetsLayer = new OpenLayers.Layer.Google('Google Streets',
> {type : G_NORMAL_MAP, isBaseLayer: true, sphericalMercator: true});
>     map.addLayer(googleStreetsLayer);
>     var mgLayers = map.getLayersByClass('OpenLayers.Layer.MapGuide');
>     if(mgLayers.length != 0)
>         var mgLayer = mgLayers[0];
>         if(mgLayer.isBaseLayer)
>             map.setBaseLayer(googleStreetsLayer);
>             mgLayer.setIsBaseLayer(false);
>             mgLayer.setVisibility(true);
> When I load my layout nothing happen, just I can see the various frames of
> the pages but they are empty.
> With the "searcher bug" of GoogleChrome I've found that "map.js": "canno't
> read property "maps" of undefined".
> Someone can help me please?
> Tnx in advance,
> Riccardo
> http://osgeo-org.1803224.n2.nabble.com/GoogleMap-on-MGOS-tp5717706p5717706.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
