[mapguide-users] Error: "Measure.FeatureSource" causing system to crash. Any advice please?
JamesDudden jamesdudden at blueyonder.co.uk
Tue Nov 16 06:13:33 EST 2010
I am running MGOS 2.02 with .NET and IIS5 and the system runs smoothly most
of the time. At the moment I am getting a lot of errors as below and MG
crashes then when restarting MG just hangs and I have to restart the server.
<2010-11-16T10:31:25> 	Ajax Viewer	127.0.0.1	Anonymous
 Error: Resource was not found:
Session:97028834-ffff-ffff-8000-005056b550f7_en_7F0000010AFC0AFB0AFA//Measure.FeatureSource
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation line 80 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
  - MgOpGetResourceContent.Execute line 120 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpGetResourceContent.cpp
  - MgServerResourceService.GetResourceContent line 863 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgApplicationRepositoryManager.GetResourceContent line 378 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
  - MgResourceDefinitionManager.GetResource line 320 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
  - MgResourceContentManager.GetDocument line 590 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
  - MgResourceDefinitionManager.GetDocument line 476 file
I know there are memory leak issues with this version but have been
reluctant to upgrade because it would be a mammoth task.
Is the measure tool to blame and is there anything I can do other than
upgrade?
Has anyone created their own measure tool?
Any help or advice is welcome.
Regards
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-Measure-FeatureSource-causing-system-to-crash-Any-advice-please-tp5743409p5743409.html
