[mapguide-users] Error: "Measure.FeatureSource" causing system to crash. Any advice please?
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 16 06:43:27 EST 2010
Zerowave can kill a hung mapguide service... no reboot required
Are you using gdal?
On 16 Nov 2010 22:13, "JamesDudden" <jamesdudden at blueyonder.co.uk> wrote:
> I am running MGOS 2.02 with .NET and IIS5 and the system runs smoothly
most
> of the time. At the moment I am getting a lot of errors as below and MG
> crashes then when restarting MG just hangs and I have to restart the
server.
> <2010-11-16T10:31:25> Ajax Viewer 127.0.0.1 Anonymous
> Error: Resource was not found:
Session:97028834-ffff-ffff-8000-005056b550f7_en_7F0000010AFC0AFB0AFA//Measure.FeatureSource
> StackTrace:
> - MgResourceServiceHandler.ProcessOperation line 80 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpGetResourceContent.Execute line 120 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpGetResourceContent.cpp
> - MgServerResourceService.GetResourceContent line 863 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
> - MgApplicationRepositoryManager.GetResourceContent line 378 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
> - MgResourceDefinitionManager.GetResource line 320 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> - MgResourceContentManager.GetDocument line 590 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
> - MgResourceDefinitionManager.GetDocument line 476 file
> I know there are memory leak issues with this version but have been
> reluctant to upgrade because it would be a mammoth task.
> Is the measure tool to blame and is there anything I can do other than
> upgrade?
> Has anyone created their own measure tool?
> Any help or advice is welcome.
> Regards
> JD
> http://www.software-matters.co.uk Software Matters -
> http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
> Database and Software Solutions
http://osgeo-org.1803224.n2.nabble.com/Error-Measure-FeatureSource-causing-system-to-crash-Any-advice-please-tp5743409p5743409.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101116/c5fcc17b/attachment.html
