[mapguide-users] Re: An exception occurred in FDO component
Dave Wilson dave.wilson at autodesk.com
Tue Nov 16 10:19:58 EST 2010
It's been a while since I've used the Maestro interface, but you have to set the X/Y columns to be your geometry columns somehow.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of FMSUSC
Sent: Monday, November 15, 2010 4:01 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: An exception occurred in FDO component
I want to link an Access table as the data source of layer. I want to use
the database rather than SHP file because I want to realize when I update
the database, the updated information can be show on the map. (Such as added
a point on website, all information as well as the coordinates is saved in
database.)
The table structure contains the attribute of
ID, X,Y, Type, and Location. only this one table right now.
I can successfully link to the shp file and got map layers well. Because of
the data synchronization I want to change it link to database directly but
not sure it's useful.
The error message shows:" An exception occurred in FDO component. Property
'Geometry' from class 'Default:test1' has no database mapping "
Thank you all.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/An-exception-occurred-in-FDO-component-tp5727051p5741944.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
