[mapguide-users] Re: An exception occurred in FDO component
JamesDudden jamesdudden at blueyonder.co.uk
Tue Nov 16 12:07:32 EST 2010
Dave Wilson wrote:
> It's been a while since I've used the Maestro interface, but you have to
> set the X/Y columns to be your geometry columns somehow.
If you are using MG Studio then there is a section called 'Define Geometry
Properties...' as below.
You need to select the table with X, Y columns and tick Geometry.
In your Access dataabse it is also a good idea to make sure the X,Y columns
are the correct data type. I use long or single.
http://osgeo-org.1803224.n2.nabble.com/file/n5744580/connection.png
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://osgeo-org.1803224.n2.nabble.com/An-exception-occurred-in-FDO-component-tp5727051p5744580.html
