[mapguide-users] Re: RE:
GordonL
gordon.luckett at arrowgeomatics.com
Thu Nov 25 12:51:48 EST 2010
Ok corrected the data issue. The order of the fields made all the
difference.
In the later version of MapGuide I had to put the Key field right before the
GEOMETERY column in the LayerDefinition xml - the only difference is that
the Order of the Properties moved the ID column in the Property Mapping.
<PropertyMapping>
<Name>ID</Name>
<Value>ID</Value>
</PropertyMapping>
weirdest bug ever.
gordon
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Selected-Object-Not-Found-when-selecting-objects-in-FUSION-tp5764720p5775090.html
