[mapguide-users] Accessing Fusion commands from parent window
Michael Adair
madair at dmsolutions.ca
Mon Nov 29 09:26:57 EST 2010
In Fusion trunk, in MapguideViewerApi.js , the reference to the Fusion
window is coded like so:
/* locate the Fusion window */
function GetFusionWindow() {
var curWindow = window;
while (!curWindow.Fusion) {
if (curWindow.parent && curWindow != curWindow.parent) {
curWindow = curWindow.parent;
} else if(curWindow.opener) {
curWindow = curWindow.opener;
} else {
alert('Could not find Fusion instance');
break;
return curWindow;
I would try that function to get it
Mike
On 25/11/2010 1:55 PM, Wilson Herrera wrote:
> Good day, everyone.
> i am designing a map and i need to reach the javascript functionalities in
> fusion (zoom rectangle, open legend window), from the parent window (that
> is, mapguide resides inside an iframe), but i havent been succesful in this
> implementation.
> to ilustrate my point, let me show you a piece of the interface.
> http://yfrog.com/3vschemayhj
> the area with the number 1, is a div inside the main window
> the area with the number 2, is an iframe, cointaining a fusion mapguide app.
> the iframe is defined as follows
> <iframe id="map" name="map" src="
> index.html?ApplicationDefinition=Library%3a%2f%2fmer%2fmer.ApplicationDefinition"
> width="100%" frameborder="0" marginheight="0" marginwidth="0">
> i try to call the functions inside in this way (and many others i forgot
> without sucess)
> 1- var Fusion = window.top.Fusion; //also tried
> window.frames['map'].Fusion
> 2- var map = Fusion.getWidgetById('map');
> and then use
> 3- map.showLegend();
> but i got errors in the first line and i think i am doing this in the wrong
> way, but my mind has been clouded and cant see what i am missing.
> im getting somewhat frustrated here and i welcome any help.
> thank you all,
> Wilson H.
> ps: this is the window layout, the same you can see in the first link.
> http://osgeo-org.1803224.n2.nabble.com/file/n5775258/schema.jpg schema.jpg
