[mapguide-users] Map3D 2011 publish to MGOS 2.1.0
Trevor Wekel
trevor_wekel at otxsystems.com
Sat Oct 2 14:44:40 EDT 2010
Hello,
Autodesk Map3D 2010 is compatible with MGOS 2.1.0 and Autodesk MapGuide Enterprise 2010. Autodesk Map3D 2011 is compatible with Autodesk MapGuide Enterprise 2011 and should be compatible with MGOS 2.2.0.
Try using MGOS 2.2.0.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of konto gmail
Sent: October 2, 2010 4:52 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Map3D 2011 publish to MGOS 2.1.0
hi
I try to publish my DWG draw from Map3D 2011 to MapGuide Open Source 2.1.0
Map3D 2011 write this error message:
Can't connect with MapGuide Server 2.1.0.4283....it is incompatible.
Map3d 2010 have no problem with that. Is there any fix for this?
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
