[mapguide-users] Map3D 2011 publish to MGOS 2.1.0
konto gmail specjal at gmail.com
Mon Oct 4 02:52:14 EDT 2010
...should be compatible with MGOS 2.2.0.
does     anybody try Map3D2011 and MGOS 2.2.0?
2010/10/2 Trevor Wekel <trevor_wekel at otxsystems.com>:
> Hello,
> Autodesk Map3D 2010 is compatible with MGOS 2.1.0 and Autodesk MapGuide Enterprise 2010.  Autodesk Map3D 2011 is compatible with Autodesk MapGuide Enterprise 2011 and should be compatible with MGOS 2.2.0.
> Try using MGOS 2.2.0.
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of konto gmail
> Sent: October 2, 2010 4:52 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Map3D 2011 publish to MGOS 2.1.0
> hi
> I try to publish my DWG draw  from Map3D 2011  to MapGuide Open Source 2.1.0
> Map3D 2011 write this error message:
> Can't connect with MapGuide Server 2.1.0.4283....it is incompatible.
> Map3d 2010 have no problem with that. Is there any fix for this?
> mapguide-users mailing list
