[mapguide-users] Re: Does mapguidedotnetapi enable backward
compatibility?
Jackie Ng
jumpinjackie at gmail.com
Tue Oct 19 18:49:43 EDT 2010
The only thing that can be considered backwards compatible is the mapagent
http interface, this is evidenced by the fact that Maestro can work with
releases of MapGuide as old as 1.2.0 (probably even older, but I don't think
anybody would run such an old version in production these days).
The official web tier API (MapGuideDotNetApi) is a different matter. Code
you write now should work for future releases, but may not be the case for
older releases.
Short answer: no
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Does-mapguidedotnetapi-enable-backward-compatibility-tp5650991p5652975.html
