[mapguide-users] Re: MapGuide ver. 2.2.0.5197 stop responding
Jason Birch
jason at jasonbirch.com
Wed Oct 20 21:22:29 EDT 2010
Oh wow.
I wonder if it would be worth seeing what effect the serverconfig.ini
RenderingServiceProperties parameters ClampPoints and GeneralizeData have on
this use case:
http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni
<http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni>I wouldn't be
surprised if this was due to the change to the Agg renderer and work done to
better represent dense data.
I'd check it out, but my test bed is down right now.
Jason
On 20 October 2010 17:28, Jackie Ng wrote:
> How many vertices does this polygon have?
> - getselectedfeatures.aspx/php/jsp stalls on MgGeometry.GetCentroid()
> - FDO Toolbox fails to get the WKT of this polygon
> - AutoCAD Map takes several mins just to draw all the snap points, with
> heavy concentrations of vertices on the "curves" of this polygon.
> Simply put: Simplify/Generalize this polygon. It is unnecessarily complex.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101020/66145a48/attachment.html
