[mapguide-users] Re: Maestro 3.0 test build #1
Jackie Ng jumpinjackie at gmail.com
Tue Oct 26 05:22:54 EDT 2010
I've modified the resource picker to allow specifying a custom starting
point, which is used by the new resource command.
When you right click and choose "New Resource", it will remember the folder
you right click and pass that on to the resource editor as a suggested
starting point when you save the resource. If you create a new resource
right-clicking Library://Foo/Bar/, when you save it will prompt starting
from Library://Foo/Bar
This will be in the next test build.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-3-0-test-build-1-tp5657585p5673941.html
