[mapguide-users] Re: Maestro 3.0 test build #1
Jackie Ng
jumpinjackie at gmail.com
Thu Oct 21 07:51:43 EDT 2010
It's a game of balance and compromise.
I wanted to make sure that anything that is saved to the library passes a
resource validation check first. That's why *all* new resources start life
in the session repository first by current design.
I guess we could pass a "hint" to the editor of the new resource as to the
suggested save location when you hit "save as" (based on where in the
repository you right-clicked when you created the resource), but I'd have to
grok the TreeViewAdv API to figure out if this can be done.
While we're on that note, it is the TreeViewAdv control which offers
selection of multiple nodes, which the Site Explorer and other tree controls
use, but it also presents an API which is totally different from the stock
WinForms TreeView control, so I am still learning how to do things with
TreeViewAdv that would've been second nature with the WinForms TreeView.
Not saying we can't do things the old way. I just haven't quite figured out
how :)
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-3-0-test-build-1-tp5657585p5658349.html
