[mapguide-users] integrate with google map
bjoseph82
brendajoseph82 at gmail.com
Sat Apr 2 00:04:02 EDT 2011
i m trying to integrate my mapguide map with the google map. when i follow
the tutorial about editing in the applicationdeffination this warning came
out? can somebody assist me about this.
Thanks very much.
Fusion Error:
WARNING: Exception occurred in AJAX callback.
Message: D is undefined
Location: http://localhost:8008/mapguide/fusion/lib/fusionSF-compressed.js
(1)
Response:
{"ApplicationDefinition":{"@noNamespaceSchemaLocation":["ApplicationDefinition-1.0.0.xsd"],"MapSet":[{"@type":["MapSetType"],"MapGroup":[{"@id":["googleBase"],"Map":[{"Type":["Google"],"Extension":[{"ResourceId":["google"],"Options":[{"type":["G_HYBRID_MAP"]}]}]},{"Type":["MapGuide"],"SingleTile":["true"],"Extension":[{"Options":[{"isBaseLayer":["false"],"useOverlay":["true"],"projection":["EPSG:900913"]}],"ResourceId":["Library://Samples/Sheboygan/Maps/Sheboygan-m.MapDefinition"]}]}]}]}],"WidgetSet":[{"@type":["WidgetSetType"],"Container":[{"@type":["UiItemContainerType"],"Name":["TaskContextMenu"],"Type":["ContextMenu"],"Item":[{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuMeasure"]},{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuBuffer"]}]},{"@type":["UiItemContainerType"],"Name":["MapContextMenu"],"Type":["ContextMenu"],"Item":[{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuRefreshMap"]},{"@type":["SeparatorItemType"],"Function":["Separator"]},{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuPan"]},{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuZoomInRectangle"]},{"@type":["SeparatorItemType"],"Function":["Separator"]},{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuZoomInFixed"]},{"@type":["WidgetItemType"],"Function":["Widget"],"Widget":["menuZoomOutFixed"]},{"@type":["SeparatorItemType"],"Function":["Separator"]},{"@type":["FlyoutItemType"],"Function":["Flyout"],"Label":["Zoom"],"Tooltip":["Open
the zoom menu"],"Item":[{"@type":
View this message in context: http://osgeo-org.1803224.n2.nabble.com/integrate-with-google-map-tp6233180p6233180.html
