[mapguide-users] RE: Unable to compile MGOS 2.2 on Linux (newbie)
ar_gaeta
ar_gaeta at yahoo.it
Mon Apr 4 05:21:03 EDT 2011
I discover my OS version:
Red Hat Enterprise Linux Server release 5.3 (Tikanga)
And I looked also at "tomcat/logs/catalina.log" (I attach the entire file at
the end).
So it seems there is another process running on port 8080... I can easily
change the port of Tomcat service? Maybe is this the cause of the
not-working Maestro?
Apr 4, 2011 10:11:42 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path:
/usr/local/mapguideopensource-2.2.0/webserverextensions/lib:/usr/local/mapguideopensource-2.2.0/lib
Apr 4, 2011 10:11:42 AM org.apache.coyote.http11.Http11Protocol init
SEVERE: Error initializing endpoint
java.net.BindException: Address already in use :8080
at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:549)
at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
at org.apache.catalina.connector.Connector.initialize(Connector.java:1014)
at
org.apache.catalina.core.StandardService.initialize(StandardService.java:680)
at
org.apache.catalina.core.StandardServer.initialize(StandardServer.java:795)
at org.apache.catalina.startup.Catalina.load(Catalina.java:524)
at org.apache.catalina.startup.Catalina.load(Catalina.java:548)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:261)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: java.net.BindException: Address already in use
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:383)
at java.net.ServerSocket.bind(ServerSocket.java:328)
at java.net.ServerSocket.(ServerSocket.java:194)
at java.net.ServerSocket.(ServerSocket.java:150)
at
org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:50)
at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:538)
... 12 more
Apr 4, 2011 10:11:42 AM org.apache.catalina.startup.Catalina load
SEVERE: Catalina.start
LifecycleException: Protocol handler initialization failed:
at org.apache.catalina.connector.Connector.initialize(Connector.java:1016)
at
at
at
at
INFO: Initialization processed in 1831 ms
Apr 4, 2011 10:11:43 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Apr 4, 2011 10:11:43 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.26
Apr 4, 2011 10:11:43 AM org.apache.catalina.startup.HostConfig
deployDescriptor
INFO: Deploying configuration descriptor manager.xml
deployDescriptor
INFO: Deploying configuration descriptor mapguide.xml
deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
Apr 4, 2011 10:11:44 AM org.apache.catalina.startup.HostConfig
deployDirectory
INFO: Deploying web application directory docs
deployDirectory
INFO: Deploying web application directory ROOT
deployDirectory
INFO: Deploying web application directory examples
Apr 4, 2011 10:11:44 AM org.apache.coyote.http11.Http11Protocol start
SEVERE: Error starting endpoint
http://osgeo-org.1803224.n2.nabble.com/file/n6237785/catalina.2011-04-04.log
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-compile-MGOS-2-2-on-Linux-newbie-tp6203409p6237785.html
