[mapguide-users] RE: Unable to compile MGOS 2.2 on Linux (newbie)
ar_gaeta
ar_gaeta at yahoo.it
Mon Apr 4 04:34:51 EDT 2011
I have a look at the logs file. Before of that, I've stopped the running and
pre-existing service httpd in 64 bit, and I launch ONLY the MapGuide
services (apache/tomcat/mgserver).
In "server/Logs/error.log": no error.
In "apache2/logs/error.log" these strings give me these errors:
[Mon Apr 04 08:11:28 2011] [warn] No JkShmFile defined in httpd.conf. Using
default
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/logs/jk-runtime-status
[Mon Apr 04 08:11:28 2011] [notice] Digest: generating secret for digest
authentication ...
[Mon Apr 04 08:11:28 2011] [notice] Digest: done
[Mon Apr 04 08:11:29 2011] [warn] No JkShmFile defined in httpd.conf. Using
default
[Mon Apr 04 08:11:29 2011] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.1
mod_jk/1.2.30 configured -- resuming normal operations
[Mon Apr 04 08:11:55 2011] [error] [client 10.127.138.93] File does not
exist:
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/htdocs/favicon.ico
exist:
[Mon Apr 04 08:11:58 2011] [error] [client 10.127.138.93] File does not
exist:
[Mon Apr 04 08:11:59 2011] [error] [client 10.127.138.93] PHP Warning:
getdate() [ function.getdate function.getdate ]: It is not safe to rely on
the system's timezone settings. You are *required* to use the date.timezone
setting or the date_default_timezone_set() function. In case you used any of
those methods and you are still getting this warning, you most likely
misspelled the timezone identifier. We selected 'UTC' for 'UTC/0.0/no DST'
instead in
/usr/local/mapguideopensource-2.2.0/webserverextensions/www/mapadmin/packagemanagement.php
on line 65, referer:
http://10.127.141.36:8008/mapguide/mapadmin/servermanagement.php?
[Mon Apr 04 08:11:59 2011] [error] [client 10.127.138.93] File does not
exist:
terminate called after throwing an instance of 'MgFileIoException*'
[Mon Apr 04 08:12:29 2011] [notice] child pid 2640 exit signal Aborted (6)
[Mon Apr 04 08:13:40 2011] [notice] caught SIGTERM, shutting down
[Mon Apr 04 08:21:25 2011] [warn] No JkShmFile defined in httpd.conf. Using
default
[Mon Apr 04 08:21:26 2011] [notice] Digest: generating secret for digest
authentication ...
[Mon Apr 04 08:21:26 2011] [notice] Digest: done
[Mon Apr 04 08:21:27 2011] [warn] No JkShmFile defined in httpd.conf. Using
default
[Mon Apr 04 08:21:27 2011] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.1
[Mon Apr 04 08:21:41 2011] [error] [client 10.127.138.93] File does not
exist:
[Mon Apr 04 08:22:08 2011] [error] [client 10.127.138.93] File does not
exist:
exist:
[Mon Apr 04 08:22:11 2011] [error] [client 10.127.138.93] File does not
exist:
[Mon Apr 04 08:22:24 2011] [notice] child pid 2986 exit signal Aborted (6)
It seems in effect that Apache stop down.
In any case, MapAdmin and MapAgent work PERFECTLY in my browser.
Thanks in advance,
R.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-compile-MGOS-2-2-on-Linux-newbie-tp6203409p6237672.html
