[mapguide-users] Re: set the hyperlink in Mapguide Meastro 3.0 b1
Jackie Ng
jumpinjackie at gmail.com
Tue Apr 5 04:52:03 EDT 2011
If the layer has the hyperlink set, you should see some indicator on the
tooltip that it is a linked layer, and you would use CTRL+click to open the
linked url. Is this not the case?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/set-the-hyperlink-in-Mapguide-Meastro-3-0-b1-tp6241223p6241541.html
