[mapguide-users] Re: set the hyperlink in Mapguide Meastro 3.0 b1
bjoseph82
brendajoseph82 at gmail.com
Tue Apr 5 20:20:17 EDT 2011
yes..it is done already. thanks everyone.
On Tue, Apr 5, 2011 at 4:52 PM, Jackie Ng [via OSGeo.org] <
ml-node+6241541-1535203802-325897 at n2.nabble.com> wrote:
> If the layer has the hyperlink set, you should see some indicator on the
> tooltip that it is a linked layer, and you would use CTRL+click to open the
> linked url. Is this not the case?
> - Jackie
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/set-the-hyperlink-in-Mapguide-Meastro-3-0-b1-tp6241223p6241541.html
> To unsubscribe from set the hyperlink in Mapguide Meastro 3.0 b1, click
> here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6241223&code=YnJlbmRham9zZXBoODJAZ21haWwuY29tfDYyNDEyMjN8LTE0NzU2MDM5NTY=>.
everyone
View this message in context: http://osgeo-org.1803224.n2.nabble.com/set-the-hyperlink-in-Mapguide-Meastro-3-0-b1-tp6241223p6244263.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110405/71072ef3/attachment.html
