[mapguide-users] MapGuide Maestro 3.0 RC1 now available
Pedro Venâncio pedrongvenancio at yahoo.com
Fri Apr 22 14:30:58 EDT 2011
Hello Jackie,
 I'm testing the MG Maestro 3.0 for the first time and found what seems to be a bug.
 I loaded a SHP in WGS84 LL and made the configuration of LayerDefinition. In the creation of MapDefinition with this shape, when save with the validator active, it shows the following error:
 Error - OSGeo.MapGuide.ObjectModels.MapDefinition_1_0_0.MapDefinition: Failed in validator:
 miny> maxy
 Parameter name: miny
 However, the extent of the map is configured correctly:
   <Extents>
     <MinX> -180 </ MinX>
     <MaxX> 180 </ MaxX>
     <MinY> -90 </ MinY>
     <MaxY> 90 </ MaxY>
   </ Extents>
 If I save the MapDefinition without doing the validation, it runs smoothly on preview, so it should be a problem in validation.
 The same happens with other Maps, with the same reference system (WGS84 LL), created in 2.x versions of Maestro.
 Can anyone reproduce the error? The shapes I am using are from http://www.naturalearthdata.com/
 Thank you very much!
Best regards,
Pedro Venâncio
--- On Tue, 4/19/11, Jackie Ng <jumpinjackie at gmail.com> wrote:
Hi All,
I am happy to announce the 1st release candidate of MapGuide Maestro 3.0 is
now available for download:
NSIS installer:
http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-3.0rc1-Setup.exe
Zip package:
http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-3.0rc1-Release.zip
Some of the changes from beta 3 include:
 - F2 keybinding to rename resource in Site Explorer
 - Add an option to determine whether to validate resources to save
 - XML Editor now has support for validating XML content against locally
installed XSD files.
 - Tabs are now colored to differentiate between active and inactive tabs.
 - Ported over missing Maestro 2.x features
    - Duplicate resource command
    - Map/Layer definition profiling
    - Batch find/replace XML content (thanks Crispin for the heads up)
    - Advanced coordinate system override functionality (thanks Crispin for
the heads up)
And an assorted range of fixes for defects discovered in beta 3 and earlier
releases.
Showstopping bugs withstanding, the final release of Maestro 3.0 will be
made available sometime next week.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-Maestro-3-0-RC1-now-available-tp6287014p6287014.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110422/149218f1/attachment.html
