[mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
Zac Spitzer zac.spitzer at gmail.com
Fri Apr 22 22:20:27 EDT 2011
what version of oracle libs are you running?
have you tried running depends.exe on the
KingOracleProvider.dll ?
(search the list archives if you need more info
about depends.exe)
On Sat, Apr 23, 2011 at 1:00 AM, Kiran Korde <kkorde at hotmail.com> wrote:
>  Hello Group,
>                  I have checked the below mentioned steps and still get the
> error message while trying to select the King.Oracle provider attached in
> the document.
> Here is the snippet from the providers.xml one as suggested by the document
> and the other with actual version number of the file. None of them work.
> This is recommended in the documentation.
>     <FeatureProvider>
>     <Name>King.Oracle.3.3</Name>
>     <DisplayName>King Provider for Oracle</DisplayName>
>     <Description>Read/write access to spatial and attribute data in an
> Oracle Spatial.</Description>
>     <IsManaged>False</IsManaged>
>     <Version>3.3.0.0</Version>
>     <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
>     <LibraryPath>C:\Program
> Files\MapGuideOpenSource2.0\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
>   </FeatureProvider>
> Here I have replaced the version number.
>     <FeatureProvider>
>     <Version>0.8.13.0</Version>
>     <FeatureDataObjectsVersion>0.8.13.0</FeatureDataObjectsVersion>
>   </FeatureProvider>
> Is there a step-by-step guide to configure and view Oracle Spatial data
> using Mapguide?
> Best regards,
> Kiran
> > From: trac_mapguide at osgeo.org
> > CC: mapguide-trac at lists.osgeo.org
> > Date: Fri, 15 Apr 2011 14:03:24 +0000
> > Subject: Re: [mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
> > Reporter: kkorde | Owner:
> > Type: defect | Status: closed
> > Priority: high | Milestone: Maestro-3.0
> > Component: General | Version: 2.0.2
> > Severity: major | Resolution: wontfix
> > Keywords: | External_id:
> > Changes (by jng):
> > * status: new => closed
> > * resolution: => wontfix
> > Comment:
> > This error has nothing to do with Maestro and everything with how you've
> > set up the FDO provider. Check the following:
> > 1. The King.Oracle provider you have downloaded is for FDO 3.3.x (this is
> > the version of FDO your MapGuide 2.0.2 is using)
> > 2. You have installed the Oracle Instant Client and that the King.Oracle
> > provider can correctly locate these libraries (OCI.dll). Loading
> > KingOracleProvider.dll into depends.exe can help determine if it can
> > locate these dlls.
> > Please use the mailing list for problems like this in the future.
> > Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1667#comment:1>
> > MapGuide Open Source <http://mapguide.osgeo.org/>
> > MapGuide Open Source Internals
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110423/f685eacb/attachment.html
