[mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro
and Oracle Spatial
Kiran Korde
kkorde at hotmail.com
Mon Apr 25 12:32:10 EDT 2011
Hello Zac,
I have installed Oracle 10.2.0.1 client. After running the depends.exe, the result came back with 2 missing dlls.
mscvr80.dll and msvcp80.dll. Should these part of the application package that I had downloaded?
I searched these files and they were found under C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2.
I copied them to \bin and \fdo folder and I still getting the same error.
Thanks,
Kiran
Date: Sat, 23 Apr 2011 12:20:27 +1000
Subject: Re: [mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
To: kkorde at hotmail.com; mapguide-users at lists.osgeo.org
what version of oracle libs are you running?
have you tried running depends.exe on the
KingOracleProvider.dll ?
(search the list archives if you need more info
about depends.exe)
On Sat, Apr 23, 2011 at 1:00 AM, Kiran Korde <kkorde at hotmail.com> wrote:
Hello Group,
I have checked the below mentioned steps and still get the error message while trying to select the King.Oracle provider attached in the document.
Here is the snippet from the providers.xml one as suggested by the document and the other with actual version number of the file. None of them work.
This is recommended in the documentation.
<FeatureProvider>
<Name>King.Oracle.3.3</Name>
<DisplayName>King Provider for Oracle</DisplayName>
<Description>Read/write access to spatial and attribute data in an Oracle Spatial.</Description>
<IsManaged>False</IsManaged>
<Version>3.3.0.0</Version>
<FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
<LibraryPath>C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
</FeatureProvider>
Here I have replaced the version number.
<FeatureProvider>
<Version>0.8.13.0</Version>
<FeatureDataObjectsVersion>0.8.13.0</FeatureDataObjectsVersion>
</FeatureProvider>
Is there a step-by-step guide to configure and view Oracle Spatial data using Mapguide?
Best regards,
Kiran
> From: trac_mapguide at osgeo.org
> CC: mapguide-trac at lists.osgeo.org
> Date: Fri, 15 Apr 2011 14:03:24 +0000
> Subject: Re: [mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
> Reporter: kkorde | Owner:
> Type: defect | Status: closed
> Priority: high | Milestone: Maestro-3.0
> Component: General | Version: 2.0.2
> Severity: major | Resolution: wontfix
> Keywords: | External_id:
> Changes (by jng):
> * status: new => closed
> * resolution: => wontfix
> Comment:
> This error has nothing to do with Maestro and everything with how you've
> set up the FDO provider. Check the following:
> 1. The King.Oracle provider you have downloaded is for FDO 3.3.x (this is
> the version of FDO your MapGuide 2.0.2 is using)
> 2. You have installed the Oracle Instant Client and that the King.Oracle
> provider can correctly locate these libraries (OCI.dll). Loading
> KingOracleProvider.dll into depends.exe can help determine if it can
> locate these dlls.
> Please use the mailing list for problems like this in the future.
> Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1667#comment:1>
> MapGuide Open Source <http://mapguide.osgeo.org/>
> MapGuide Open Source Internals
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110425/13450908/attachment.html
