[mapguide-users] OGR Calculation with Personal GeoDatabase
    Traian Stanev
    traian.stanev at autodesk.com
    Wed Apr 27 21:49:59 EDT 2011
Hi Gordon,
Computed properties are not implemented in the OGR provider. You can create an enhancement request, but it will not be a high priority item to implement, unfortunately. As a workaround, you can consider exporting your data to SQLite, SHP or SDF.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
Sent: Wednesday, April 27, 2011 3:48 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] OGR Calculation with Personal GeoDatabase
Hi All,
does anyone know how the run a Calculation on a field using the OGR Provider with GeoDatabase (*.mdb).
i.e.  Area2D (Geometry)  works on a SHP or SDF but not the OGR with GDB.
thanks
gordon
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OGR-Calculation-with-Personal-GeoDatabase-tp6310921p6310921.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
