[mapguide-users] Re: Expression editor - Work on date filter
Jackie Ng jumpinjackie at gmail.com
Mon Aug 1 02:57:46 EDT 2011
There doesn't seem to be any FDO expression function to subtract days from a
datetime.
You'll have to either try seeing if you can pass in a PGSQL where clause as
the FDO filter (this may or may not work). Otherwise you'll have to make a
view in Postgres that is specifically shaped to make this sort of query you
are after feasible in FDO.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Expression-editor-Work-on-date-filter-tp6630216p6640004.html
