[mapguide-users] RE: Show/Hide Layers and properties pane by
script
andrea tiveron (e-metodi)
andrea.tiveron at e-metodi.it
Mon Aug 1 03:45:49 EDT 2011
Elliot
you're right
I'm sorry but I do not use the properties visible
I've added the following line of code:
try { xframe.SetPropertyPaneToolbarVisibility(true); } catch (e) { } I used
the command try to ensure compatibility with previous versions to 2.2
so I reviewed the code again:
var xframe = GetMapFrame();
var aryClassElements = new Array();
var objBtn;
function findbtnbytitle(titolo) {
imgs = xframe.parent.frames[0].document.images;
for(i=0;i<imgs.length;i++){
if(imgs[i].title==titolo){
objBtn =imgs[i]
return objBtn;
if(xframe.document.getElementById("InfoBand").style.width ==
'0pt')
xframe.minInfoWidth=20;
xframe.ResizeTo(200);
xframe.InitialMapView(); objBtn = findbtnbytitle('Apre il pannello dei
layer'); objBtn.src='../stdicons/openButton.gif';
objBtn.title='Chiude il pannello dei layer'; }
else
xframe.minInfoWidth=0;
xframe.ResizeTo(0);
xframe.document.getElementById("LayerCaption").style.width = 0;
xframe.document.getElementById("LegendCtrl").style.width = 0;
xframe.document.getElementById("PropertyCaption").style.width = 0;
xframe.document.getElementById("PropertyCtrl").style.width = 0; try {
xframe.SetPropertyPaneToolbarVisibility(false); } catch (e) { }
xframe.InitialMapView(); objBtn = findbtnbytitle('Chiude il pannello dei
layer'); objBtn.src = '../stdicons/closeButton.gif'; objBtn.title='Apre il
will need to pay attention to the replacement of the title text button
with regard to your second request, I do not know if I understood exactly in
my interface, I have the buttons to show and hide the panels just as you say
I enclose a picture attached
regards
andrea
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of elliott17
Sent: giovedì 28 luglio 2011 15:23
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Show/Hide Layers and properties pane by script
When hiding the layer and properties pane while objects are selected, the
small window stays visible where the user can select the object type and the
drop down list of objects are accessible. This is just below the Properties
title.
Also, is there a way to configure a button that can sit at the top of the
layer bread, mush like the arrows that show and hide the taskpane.
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Show-Hide-Layers-and-properties-pane-
programmatically-tp1809391p6629849.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This message was scanned by ESVA and is believed to be clean.
