[mapguide-users] Postgres view on MGOS
Zac Spitzer zac.spitzer at gmail.com
Mon Aug 1 08:54:04 EDT 2011
was the view created in mixed case with quotes?
On Mon, Aug 1, 2011 at 10:51 PM, ar_gaeta <ar_gaeta at yahoo.it> wrote:
> Hi all,
> I've some problem to let MGOS 2.2 recognize my geometric view on PostgreSQL
> 8.4, PostGis 1.5.
> The other geometric tables are fully recognized and well working under MGOS.
> I've followed the guide by Jackie, about edit the configuration document
> using FDO Toolbox:
> http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
> Under FDO Toolbox, I set the primary key of the view, and I repeat the
> procedure in MGOS, using Maestro 2.1.4 (the same procedure of copy/paste the
> xml configuration document didn't work in Meastro v3).
> Note: the geometric field "the_geom" of the view is recognized from MGOS as
> a geometric field, even if I had to manage the xml configuration document to
> specify that the geometry was only point.
> Now, MGOS is NOT able to plot my points data, when I validate the
> FeatureSource I don't get fatal error message, but when I preview the
> connection, I'm not able to see both data and features of my view. I get
> this error:
> "An exception occurred in FDO component. Table does not exist for class
> 'public:my_view'"
> What does it mean this error? How can I solve it?
> Thanks for all your attention,
> Riccardo
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Postgres-view-on-MGOS-tp6640881p6640881.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
