[mapguide-users] Properties item list
elliott17 elliottd at ae.ca
Tue Aug 9 17:51:20 EDT 2011
Using MGOS 2.2 AJAX - When objects are selected in the map, the properties
pane lists the objects and the user can select an object by selecting a
number from the drop down list.  Where does this number (1,2,3, etc) come
from and can another attribute be used for this drop down list?
If I have my own ID column, can I use my column?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Properties-item-list-tp6669969p6669969.html
