[mapguide-users] Properties item list
GIS4U
johnniegis at gmail.com
Tue Aug 9 18:10:05 EDT 2011
The list is displaying the count of the values in the array. While I
haven't done it specifically, you should be able to display values in there
instead. You should be able to modify the propertyctrl.templ file in the
viewerfiles directory. Make sure to back it up first as breaking it can
break your site.
Regards,
Jonathon
On Tue, Aug 9, 2011 at 2:51 PM, elliott17 <elliottd at ae.ca> wrote:
> Using MGOS 2.2 AJAX - When objects are selected in the map, the properties
> pane lists the objects and the user can select an object by selecting a
> number from the drop down list. Where does this number (1,2,3, etc) come
> from and can another attribute be used for this drop down list?
> If I have my own ID column, can I use my column?
> http://osgeo-org.1803224.n2.nabble.com/Properties-item-list-tp6669969p6669969.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110809/f437c9f3/attachment.html
