[mapguide-users] Re: Updating datasets in MGE. (sdf, or dwf)
GordonL gordon.luckett at arrowgeomatics.com
Thu Aug 11 16:44:02 EDT 2011
It could be that the SDF is cached. in the serverconfig.ini  the SDF is
usually part of the excluded list.
FROM THE WIKI:
DataConnectionPoolExcludedProviders ¶
By default, SDF data sources do not use pooled connections. This allows
read/write operations to occur. Some performance improvement can be obtained
by enabling connection pooling for SDF and SHP. Note: Turning on connection
pooling for SDF will make SDF unsuitable for FDO update operations. If
temporary layers are constructed using SDFs, connection pooling must be
disabled for SDF.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Updating-datasets-in-MGE-sdf-or-dwf-tp6677977p6678029.html
