[mapguide-users] RE: Is GDAL working and Stable in 2.2?
Mike Micallef Michael.Micallef at ontario.ca
Fri Aug 19 08:00:17 EDT 2011
Thanks Trevor,
That was very clear -
I appreciate the time you have spent on this already - as well as all
the other developers' contributions.
It has been a bit of an uphill battle getting an Open Source footprint
in the Ministry - these efforts help a great deal in utilizing the tool.
Thanks again,
Mike
Michael Micallef, PMP
Regional GIS Coordinator
Ministry of Transportation
659 Exeter Rd, London, ON, N6E 1L3
519-873-4416
michael.micallef at ontario.ca <mailto:michael.micallef at ontario.ca>
[mailto:ml-node+6700916-703622224-252211 at n2.nabble.com]
Sent: August 18, 2011 5:18 PM
To: Micallef, Michael (MTO)
Subject: RE: Is GDAL working and Stable in 2.2?
Hi Mike,
I have successfully performed lightweight load testing on the 64 bit
Windows build with some ECW, MrSID, and TIFF data using the information
contained at http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider.  So
yes, for my data set I would say that it is stable.
There are a few limitations which may impact your implementation:
Occasionally MapGuide does not correctly return the extents or
coordinate system of the raster data.  This makes authoring more
difficult.  Jackie has a patch to improve this behaviour attached to
http://trac.osgeo.org/mapguide/ticket/740.
The FDO GDAL Provider has only been tested with a single connection.
[FeatureServiceProperties]
DataConnectionPoolSizeCustom = OSGeo.Gdal:1
Enabling multiple connections may cause raster to go unstable.  This
means that MapGuide and FDO GDAL will only process one raster data set
concurrently.  If you have a lot of users and a lot different raster
data sets, this could be a significant bottleneck.
I would like to take another pass at MapGuide & FDO GDAL for the 2.4
release.  There is some interest in adding configurable resampling
(bilinear, cubic, etc) and we really do need to remove the single
connection limitation.  I can make time available to do this work if
funding is available.  This would move MapGuide + FDO GDAL Provider
closer to parity with MapGuide + Autodesk Raster Provider.
Regards,
Trevor
-----Original Message-----
From: [hidden email] [mailto:[hidden email]] On Behalf Of Mike Micallef
Sent: August 18, 2011 2:20 PM
To: [hidden email]
Subject: [mapguide-users] Is GDAL working and Stable in 2.2?
Not complaining - just discouraged...
Is GDAL working and stable in 2.2 - all kinds of different and older
posts
out there about partial work-arounds, Trevor's investigation, locking it
up,
this is the problem, that's the problem...
We use imagery and it has been a struggle migrating through the releases
and
trying out the fixes - I do not want to move until I am sure how to
handle
the imagery.
We have custom code all over the place and to migrate is a bit of an
undertaking....
m
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Is-GDAL-working-and-Stable-in-2-2
-tp6700721p6700721.html
mapguide-users mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/mapguide-users
[hidden email]
If you reply to this email, your message will be added to the discussion
below:
-tp6700721p6700916.html
To unsubscribe from Is GDAL working and Stable in 2.2?, click here
<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=u
nsubscribe_by_code&node=6700721&code=TWljaGFlbC5NaWNhbGxlZkBvbnRhcmlvLmN
hfDY3MDA3MjF8NjgzMzMyMDMw> .
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-GDAL-working-and-Stable-in-2-2-tp6700721p6702907.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110819/b2b630b6/attachment.html
