[mapguide-users] Some fusion success
djonio
DJonio at miami-airport.com
Tue Dec 6 08:01:03 EST 2011
Zac/Jackie/et.al.
I did get the source from the fusion trunk as suggested. That and the build
was fairly straightforward.
"really finally production ready" ... I am still not sure but I must tell
you that 1) it does not error out on the initial load!!! 2) it does produce
a map!!! 3) it does finally produce a legend!!! (I never thought that 49
items was extreme)
Are the MGOS 2.2 installer provided fusion templates _in sync_ with this
fusion trunk build? I believe aqua and limegold have some issues. The others
seem to work.
At least for now, all I see is speed as an issue. Do you know of a
compatible _vector feature source tiling engine_?
r,
dennis
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Some-fusion-success-tp7066723p7066723.html
