[mapguide-users] Some fusion success
Zac Spitzer
zac.spitzer at gmail.com
Tue Dec 6 08:25:01 EST 2011
Glad you had some success!
On Wed, Dec 7, 2011 at 12:01 AM, djonio <DJonio at miami-airport.com> wrote:
> Zac/Jackie/et.al.
> I did get the source from the fusion trunk as suggested. That and the build
> was fairly straightforward.
> "really finally production ready" ... I am still not sure but I must tell
> you that 1) it does not error out on the initial load!!! 2) it does produce
> a map!!! 3) it does finally produce a legend!!! (I never thought that 49
> items was extreme)
how slow is the legend, there are some plans to migrate the approach
used in php to generate the legend back into the server.
how does it compare to the AJAX viewer? you can configure how many
legend images are produced,
how many layers have heaps of themes, ie icons per layer?
> Are the MGOS 2.2 installer provided fusion templates _in sync_ with this
> fusion trunk build? I believe aqua and limegold have some issues. The others
> seem to work.
you might want to try grabbing the trunk fusion templates
if you are having issues
> At least for now, all I see is speed as an issue. Do you know of a
> compatible _vector feature source tiling engine_?
have you tried using mapguide base layer groups?
> r,
> dennis
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Some-fusion-success-tp7066723p7066723.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
