[mapguide-users] RE: Points from Sql/ODBC data source not showing
GordonL
gordon.luckett at arrowgeomatics.com
Tue Dec 6 10:41:01 EST 2011
In your final view in SQL Server 2008, you should just create a Point object
with your two x and y columns.
like this:
/select geometry::Point(g.PNT_X,g.PNT_Y,0) as GEOM
FROM tbMYTABLE g/
Then you can use the FDO for SQL Server Spatial rather than ODBC.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7067220.html
