[mapguide-users] Re: Configure Dataconnection to SQL Server 2008
Michael Kohler
mkohler at hinton.ca
Wed Dec 7 12:36:41 EST 2011
Hi Sandra, I've read you responses and am still not clear on the exact syntax
that you use. When you said that you replaced the servername with localhost
would the connection string look like:
Driver={SQL
Server};Server=localhost;Database=MyDB;Uid=mapguide;Pwd=HelloWorld;
And localhost is the address for the server?
Thanks,
Michael Kohler
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Configure-Dataconnection-to-SQL-Server-2008-tp5158450p7071351.html
