[mapguide-users] One final breaking API change for Maestro 4.0
    Jackie Ng
    jumpinjackie at gmail.com
    Thu Dec  8 05:37:52 EST 2011
Hi All,
It seems there's a few people on this list using the near-final Maestro 4.0
API. Given the huge volume of breaking API changes since 2.1, I might as
well inconvenience you lot with one more API change before the final 4.0
release :-)
All the RuntimeMapLayer constructors will no longer be public. I will add
equivalent CreateMapLayer() methods in the IMappingService interface as
replacements.
So instead of this:
RuntimeMap map;
ILayerDefinition srcLayer;
RuntimeMapLayer layer = new RuntimeMapLayer(map, srcLayer);
Do this instead:
RuntimeMap map;
IMappingService mappingSvc;
RuntimeMapLayer layer = mappingSvc.CreateRuntimeMapLayer(map, srcLayer);
The purpose of this change is to facilitate post-4.0 API work in adding an
alternate implementation of RuntimeMap and RuntimeMapLayer classes that
directly wraps MgMap and MgLayer (from the official API) respectively.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/One-final-breaking-API-change-for-Maestro-4-0-tp7073891p7073891.html
