[mapguide-users] SQL Server 2008 R2 synchronization
elliott17 elliottd at ae.ca
Wed Dec 14 12:16:30 EST 2011
I have layers created that are read from SQL Server 2008 R2.  What I have
found is if I edit the schema (sort columns or rename a column) in SQL
Server, the layers need to be refreshed by saving the data connection in
Maestro/Studio and the layer needs to be saved.
When I change the column name, I have seen that layers will not be
selectable and I need to re-create the entire layer.  Is there a
synchronization step in Maestro that I have overlooked?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQL-Server-2008-R2-synchronization-tp7094275p7094275.html
